Old 10-28-2009, 02:21 PM   #1
Awning brackets for voyager top
I'm having a voyager top put on my build at SMB. Would someone with a voyager top tell me if there is enough space left over the gutter (e.g. 3/4 inch) for Eli's brackets? I doubt that their is but I'd like to use them if possible. Thanks
dowgars is offline   Reply With Quote
Old 10-28-2009, 02:39 PM   #2
Re: Awning brackets for voyager top
SMB bolted my Fiamma directly to my Cruiser top
it is solid
i am 100% happy with it
make sure they put in some backing plates
i am pretty sure the same applies to a voyager
ps
cruiser top is ALOT bigger inside
gas milage difference probably not to much difference
i had a choice cruiser vs voyager
i am really glad i have a cruiser
i am 6ft, wife is 5 and change
one 20 pound dog
my 2 centavos worth
ps
thanx to the cruiser top and my aluminess rack
FULLY packed for camping the only think out is
a large soft duffel in the overhead with double sleeping bag and two pillows
Old 10-28-2009, 05:33 PM   #3
Thanks Bill: I have a regular body or I would have ordered the other top.
Old 10-29-2009, 12:08 AM   #4
I have the voyager top. I'll measure the gutter space tomorrow and report back.
As for bolting directly to the top: The fiberglass thickness and strength should be the same as a crusier, so if it's working for Bill it should work for you. Your biggest concern will be to protect the gelcoat from cracking and leaking.
As a carpenter, former mechanic and automotive hobbist, I would recommend using 1/4" or 3/8" x 3" x 3" plywood washers inside the top. (You coud also use metal washers if excessive thickness is a concern. I prefer the plywood as it is a little more forgiving and will help absorb any deflection) Also use a couple layers of bituthane tape or 1/8" thick bed of bituthane caulking between the plywood washer and the inside of the top. this will accomodate for the semi-rough interior surface and also help waterproof the bolt penetration. A piece of bituthane tape should also be used between the awning mounting bracket and the exterior surface of the top. Creates a nice waterproof sandwich. - that's how I would do it anyway.
Good luck!
2000 Ford Econoline E-350, EB w/Hi-Top, 7.3 Turbo-Diesel, 2wd - Home-build in progress
Gulliver is offline   Reply With Quote
Old 10-29-2009, 01:57 AM   #5
Send a message via MSN to saabman
Hi
I used the standard Fiamma mounts which normally are used on fixed top vans:
Notice the 2 lugs on the Fiamma plate well they would just bolt strait into your roof of course with adequate sealing...
Check out:
http://www.fiammausa.com/products/acces ... =A2&BG=F45
+ 2001 Saab 9-5 Aero Hirsch
+ fixed house (Argh)
Old 10-29-2009, 11:06 AM   #6
I appreciate all your responses. RD
Old 10-29-2009, 12:25 PM   #7
DisabledExplorers's Avatar
I will be at SMB West this afternoon and they mounted my Fiama awning right through the voyager top. If I can get any good pics I will post them up along with a description of how it was done.
Go out and play in the dirt!
DisabledExplorers is offline   Reply With Quote
