Old 07-12-2018, 02:53 PM   #11
mkkbven's Avatar
I make magnetic curtains. K&J Magnets have magnets with holes in the center which are easy to sew in the curtain edges. If you want insulated black out curtains, a product called Warm Window is also easy to work with. Karen
Mark & Karen
2013 SMB Sprinter RWD RB w/ Penthouse
mkkbven is offline   Reply With Quote
Old 07-12-2018, 05:15 PM   #12
Black out curtains
I used black color black out material I purchased online from Seattle Fabrics.
I attach using velcro on some windows and bungee cord through a sleeve sewn into the top of the curtain on other windows. Has worked great and fabric is good quality and easy to sew.
azjim is offline   Reply With Quote
Old 07-17-2018, 06:18 PM   #13
JoeyNick's Avatar
Originally Posted by Cruzliife View Post
Looking for suggestions on where to buy black out curtains Or ideas on how to make easy ones without rods and all the extras. Something simple that deploys and stowaways easy is best.
Thanks!
My blackout curtains connect with snaps and they are made from the same material as the rest of the interior of my van.
They are very easy to make and the snaps I used are the type with a screw hole in the middle. I used mostly existing screw points around the windows for the male part of the snap. The female curtain half installs with a hammer and die, easily done with a single blow.
JoeyNick is offline   Reply With Quote
