My original idea for my van was to use the espar hydronic as my sole source for heat and hot water as well. I set up anouther van like this and was unhappy with this set up mostly because of the noise of the hydronic and the time/energy required to heat the interior. I do however have the indel marine dual coil hot water heater. If you do a little research and check out Earthroamer, The Turtle, RUF Fabrication, Unicat etc. they are all using both the hydronic and the airfurnaces together.
Seth Hatfield
'05 EB350 6.0 4x4
Homebuilt Interior
Santa Barbara Ca
