Old 06-25-2009, 12:21 PM   #1
New Roof Air on 2001 Cruiser Top
Folks
SMB indiana said they cannot put roof air on a used rig
I have a line on a 2001 Cruiser top but my needs are for Air con
to be run with generator
any thoughts/experiance/ ideas are welcome
thanx in advance
BW
Old 06-25-2009, 01:24 PM   #2
Re: New Roof Air on 2001 Cruiser Top
Step 1: call again tomorrow.
Step 2: call again later in the day and talk to someone else.
Step 3: call another SMB location (e.g. Austin)
Repeat @step 1 until you get the answer you want.
Or- a standard RV shop may also be able to do this, since the roof AC is the type they're probably more used to.
Also you'll want to clarify "cannot" vs. "will not". SMB Indiana wouldn't even talk to me about putting another battery in my used SMB, so YMMV.
and then
everything changed
Old 06-25-2009, 01:28 PM   #3
LOL
just like my business, i gotta call 3 times to get the "real" answer
just spoke w/ smb fresno, no problem to install
will keep ya all posted
bw
Old 06-25-2009, 03:03 PM   #4
Thats funny...I just removed my Coleman Mach III roof heat and air to install a Fantastic vent fan. I just posted it on Craigslist! Anyway installation is simple. Most roofs allready have a standard 14" roof vent or a simple square hole can be cut. You lay the roof unit on the roof and screew a retaining ring in from the inside. 4 more screews to hold up the grill and controll unit. It has standard 3 wire AC connections and with a little caulk your done. Any RV place or handyman could do it in a couple of hours but it's a DIY project especially if you all ready have a 14" vent hole in your top and you can muscle the unit on the roof. http://www.expeditionportal.com/forum/s ... hp?t=28272
Stumpalump is offline   Reply With Quote
