Re: No Propane Water Heater in RB?
So I just got some more info. about the Espar heater. Looks like that since it will be gasoline powered, it needs to mount externally. Correct?
Would I even need a flat plate? I don't wish to heat engine coolant.
Can the Espar be mounted so that it's in-line with my hot water lines and when commanded (by a switch inside the van) it will turn on and heat water in those lines? It looks as if it's just plumbed into a water source. Turn it on and it heats water as it flows through the heater. Maybe I'm missing something...once I hit 40 my smarts started to dimimish
Build in planning stages - SMB-West or UJOR 4x4, V-10, Pueblo Gold, lots of other stuff...
