Originally Posted by LandVan
What are those thin cable wires used for? I have them also but cant figure out their use.
Also, what is the purpose of those small cleats? I am missing one but haven't seen the reason to replace it
The thin cable wires are attached to the underside of the PH. There are two at the front and one at the back. There are corresponding cleats attached to the bed. When the wire is attached to the cleat the bed rises up and out of the way when the PH is raised. When detached, the bed stays in place when the PH is raised.
