Hi all - looking for input installing a new gasket: at the front penthouse corner there is a gap on either side of that corner fastener. The gaps don't run very long but an opening up 1/4 inch seems like a perfect place to collect debris & road grime.
Is this a matter of tension? I tried to keep the new gasket taut but didn't really stretch it. The bottom penthouse edge is well seated within the new rubber.
At the rear, the bottom of the fiberglass stays on the same horizontal plane as it rounds the corner & installation was without issue. In front, the edge rises around the corner to follow the van roofline.
Thanks in advance for your guidance
