We have a 2002 E-350 EB Sportsmobile with Quigley 4WD with a custom interior that is going to need some modifications to support an expected second child this fall. I have been thinking a lot about the "ideal" floorplan for a family of four. Based on my experience with our van, and being in and out of some friends' vans, I have decided what the ideal floorplan would be for us. Having experienced my Quigley and a couple of Quadvans (2" and 4"), the 4" Quadvan lift with Deaver rear springs is hands down the best choice if you're choosing between Quigley and Quadvan for 4WD. Plus, you can always try 2WD and pay for the Quadvan conversion only if you decide you need it. Don't get me wrong, my Quigley works fine, but Quadvan is better - more stable, more stock, handles better.
So here it is:
- Four captain's chairs. Second row close to the first row for easy communication and hand-offs to the kids.
- 2nd row captain's chairs should be easily removable.
- Passenger chair and 2nd row chairs should swivel.
- Left side rear fridge, sink, storage, counter, furnace, electrical.
- Right side rear gaucho that folds down into a bed. Gaucho needs to be removable. Leaves the center aisle open when traveling if you need to put boards (or in my case, bikes or kayaks) inside for some reason. Also provides room to work at the galley area.
- By having all the seats removable, you have the opportunity to mix and match as needed.
Check out this post for something similar:
viewtopic.php?f=7&t=5761
Like I said, that's my ideal layout. You have to figure out what works for you. I think the 4 captain's chairs are key, especially with younger kids. If you want to more safely seat 4+, go with a normal bench behind the captain's chairs, but you will have to figure out your galley access, and you lose some of the storage flexibility that the center aisle provides. Check out Bitburger for this option.
I'm sure that if I ever rebuild to the "ideal", I will find its flaws and start dreaming of the new "ideal". Good luck with your quest!
