Re: Water tank - what to get?
I really like the propane h/w tank as I run it overnight and it stays hot-warm all day. Showers don't really take much water, you're not standing in there like at home- rinse with the button, soap up, shampoo, rinse. It's not as much fun as it looks standing behind the bumper in 40° F and showering. It also give ~6 gallons of emergency water (not normally accessible).
My suggestion is to go with the 17g SMB tank and then worry about adding water storage yourself once you're accustomed to your needs and can find all the options... SMBs decisions might not be ideal past 17g, and with the one tank all the hard stuff is done. There are so many solutions, from under van containers, to Scepter, to PVC, collapsible jugs, to those 5 gallon water bottles (which fit perfectly behind the pantry in some vans), that taking up storage at build time with another tank would seem to be option limiting.
Incidentally I've only filled my 17g tank once while on an extended trip. I usually bring back more than half, even when out for more than 10 days, and that includes refilling the porta-potty flush tank from the van tank.
