Originally Posted by 86Scotty
Once you learn how heavy a Honda 3000 generator is you won't want to put it on anything,
Shipping weight seems to be just under 150lbs, so a hitch carrier should work ok. I've got more than that in my Aluminess box, but I doubt the 3000 would fit. Still, that's a really heavy generator, and probably larger than needed. A 15K BTU unit will run fine on a 2000, and it would probably support an even larger unit if there was room enough to mount it, but I wanted mine in the door. I would love a bigger A/C, but space limitations don't allow it. If I were routinely traveling in a hotter climate I'd consider finding a way to mount a bigger unit, but the smaller one really takes the edge off.
