CB Antenna Whip Mount
Originally Posted by BrianW
Jage, how did you get the antenna wire from the cabin into the engine compartment? I just redid my headliner (wow, that was a LOT of fun) and prewired for the CB and antenna, but don't see any obvious path to get the coax out into the engine area.
On the Fords, there's a rubber plug near the front door hinges that passes into the footwell area. Then, from the hinge area, it's a simple route through the fender cut out into the engine area.
My alarm installer went a different route. He drilled a small hole just above and to the left of the brake pedal to pass his wires, after he put a grommet in the hole he drilled. He then filled the remaining space with a goopy rubber compound.
