Old 01-07-2009, 09:54 PM   #11
dave_in_delaware's Avatar
Send a message via Yahoo to dave_in_delaware
Isn't there some sort of pressure issue w/ these propane canisters/tanks? Just dumping some propane from one into the other seems a bit... scary to me....
Dave
Homebuilt RV Project: Design Phase is 80% Complete! (but on hold until I win the lottery)
Ford E-350 EB w/ Cruiser Top, Flip-down "Gaucho" sofa/bed, custom cabinets, AGM batteries, solar panels, water heater, fresh/gray water tanks, sink, porta-potty....
dave_in_delaware is offline   Reply With Quote
Old 01-08-2009, 09:55 AM   #12
scatter's Avatar
From what I've been told, and it makes sense, the 16 oz. is designed for the same pressure as the bigger bottles. Unless you've got some ungodly pressure pump doing the transfer, you'll be fine. I would be a little concerned about refilling one too many times as there really are designed for a single use.
I do remember, way back in the olden times, that there were some of the little bottles that were designed for refilling and they had a relief valve built in. They haven't been around in decades, or so I'm told.
Scatter
2007 RB50, 6.0
K1WGB
Old 01-08-2009, 02:22 PM   #13
I've only been around for decades and I've seen the little greenies with a release valve (always wondered why there was a schrader valve in some).
I think one obvious problem would be with leaking once refilled. As long as they are attachec to something that can be shut off they're fine, but even the new ones will leak if I pull them off the stove or lantern fixture.
I actually keep a propane torch around because I can store half used bottles with it installed and they take up less space.
