Old 09-12-2007, 11:21 PM   #1
Buji's Avatar
Dog Kennel that FITS PERFECT.
There's a space in my roof where the bed panels could slide forward. I found something else to fit there.
Basically it's a collapsible dog kennel for large dogs that fits in this spot PERFECTLY. As we all know, space is a premium in the rig, and if you find an accessory that fits perfectly, it's worth it's weight in gold.
Here's a view of it with the top down from the inside.
It hangs down just a little lower than the bed panels, and things (blanket, towel, etc) can be stuffed in there .
*I have a door on the left which goes to the shower/toilet closet, and the kennel just needs to be pushed on a little to allow the door to open. In my layout, this also helps keep the door from rattling too much on washboards.
It is exactly the same width as the bed panels, as seen in this picture. This should work regardless of your layout.
Also it can be folded up against the front of the PH top if you're not going to 'deploy' it.
This is a picture from the open cargo doors of the kennel stowed.
This is how the folded kennel looks outside of the van.
Kennel fully deployed with my research assistant. He's an 80 lb black lab and we use this kennel at home as well as on the road. He's kennel trained and prefers to sleep in the kennel. While on our trips we can deploy the kennel inside the van (if the bed is layed out) with chew toys and we don't have to worry about him trying to chew any of the cabinets. (he's a young lab, and I'm pretty sure we're beyond that but still...)
Also, we can deploy it at a campsite if he's being a bother and the chain isn't sufficient, or when we were at my parents house we used it inside.
The kennel is a large sized Home 'N Go brand collapsible kennel.
Measures:
42"x28"x31" deployed
42"x28"x~5" folded.
It has two straps which help compress the kennel on either side and a nice carrying handle.
The large kennel weighs about 13 lbs and is more cumbersome than heavy, but not a chore for one person to stow or deploy, once they have the hang of it.
I would say the kennel is sufficient for an aggressive chewer for short periods of time if they haven't been kennel trained. It's definitely sufficient if they have. It's surprisingly durable and well made. You could also put this on top of the penthouse short panel for a small pet penthouse if you needed to.
I have other accessories I've fitted to the van which also FIT PERFECT and I'll start documenting them as a series (workload permitting).
Let me know if you have any questions.
-Buji
_________________________
Modified EB-22 with Penthouse Top
https://www.sportsmobileforum.com/alb...43791a54be.jpg
Buji is offline   Reply With Quote
Old 09-13-2007, 05:39 AM   #2
Dog Kennel
Buji, our labradog kennel is about 20ft by 8ft with a penthouse top.
2006 Baja Tan SMB 4X4 EB50 PH 6LPSD
Mohawk Royalex Solo 14 foot canoe (light white-water)
Mad River Kevlar Explorer 17 foot canoe (flat water)
Dagger Royalex Legend 16 foot canoe (white-water)
Maravia New Wave 13.5 foot raft (fishing and white-water)
Ed in Montana is offline   Reply With Quote
Old 09-13-2007, 06:04 AM   #3
Dog Kennel
Here's the 60lb yellow dog ready to go in the four wheel drive kennel:
And the 110lb extra-large black labradog loading up on the two stools we bought to make dog loading easier:
The getting in and out with the high floor level of a 4X4 has proven to be the hardest part of dealing with large dogs, especially when they are tired after a hike or swimming. The two aluminum stools from SafetyStep.com help tremendously, and the smaller stool collapses and can be stored in the back of the SMB.
Cats are not permitted in this version of the four wheel drive dog kennel.
Ed in Montana
Old 03-10-2009, 10:19 PM   #4
Re: Dog Kennel that FITS PERFECT.
Great notes...I have one of these kennels stowed away in our garage...happy to sell cheap if someone wants/needs one. (Our lab chewed hers to shreds years ago...)
mamaupupup is offline   Reply With Quote
Old 03-11-2009, 06:27 PM   #5
Greg In Austin's Avatar
I was beginning to wonder if Buji had a dog to go with that kennel.....
...but it is a good fit either way...
Greg in Austin
