Old 10-14-2018, 02:08 PM   #11
Originally Posted by TomsBeast View Post
2:25 is the part about smooth ride over rocks and such. Not so much with a short sidewall tire
That is great info!
So, what PSI do most of us run at on the highway? I usually keep my 285R70-17's at 45-ish psi. The ride is way more comfortable, and I seem to be getting fairly even tire wear. I usually air up to about 60-70psi when I tow (7k lbs Airstream).
"Life moves by pretty fast, if you don't stop and look around once in a while, you could miss it." -Ferris Bueller
lavolpe79 is offline   Reply With Quote
Old 10-14-2018, 04:30 PM   #12
Twoxentrix's Avatar
Originally Posted by lavolpe79 View Post
That is great info!
Sounds like you already have the answer(s) to your own question...
Old 10-14-2018, 08:51 PM   #13
That’s what I do. I was wondering what most other people do.
Old 10-14-2018, 09:45 PM   #14
shenrie's Avatar
I’ve dropped mine from 65 on each corner to 50. Rides better so I haven’t messed with it since.
