Old 01-05-2014, 09:52 PM   #11
Re: MAXTRAX -- Roof Mounting?
Geoff, I don't know why you couldn't use a couple of pieces of flat aluminum and use the locking mounts maxtrax sells. I'd think that the double sided tape others are using to hold their solar would work or bolt it to the side like the Aluminess rack is. I'd hate to see those fly off if I were following you on the highway...they're kind of heavy. Mine are attached to my ladders which I see you don't have.
Old 01-07-2014, 06:35 AM   #12
I have mine mounted rear on roof rack and may be a picture on my gallery or I can get you one.
carl
2010 SMB
Old 01-09-2014, 05:56 PM   #13
geoffff's Avatar
OK, here they are -- I went and made the purchase! These are my two new Maxtrax resting on my roof behind my solar panels. I'm thinking of running some kind of flat metal bars back from my solar panels mount (making use of their existing attachment to the roof) and connecting the MaxTrax to these new bars.
Don't worry, my glue/tape idea has been discarded :O
-- Geoff
2004 Ford, SMB 4x4, RB-50
Old 01-30-2014, 10:42 AM   #14
geoffff's Avatar
OK, here's what I ended up doing. First, I placed a 1/2" rubber mat on my roof to prevent rattles & rubbing. The front side of the Maxtraxes are held in place by tucking under a pair of tabs (1/8" thick angle aluminum) I mounted on the rear side of my solar panels. The rear side of the Maxtraxes are tied down to a bar of angle aluminum I attached to two bolts that were already there on my roof. The distance between these repurposed bolts-ends and the solar panel happens to exactly match the width of the Maxtrax, so it's a snug fit.
-- Geoff
Old 01-30-2014, 12:11 PM   #15
Looks nice Geoff, but that PH hardware is starting to show its age.
Old 01-30-2014, 03:16 PM   #16
geoffff's Avatar
Too much beach & Black Rock Desert corrosive camping
--Geoff
Old 10-23-2014, 06:19 AM   #17
JohnandMandi's Avatar
Attachment isn't showing in the quote... so this has been edited.
DaveB
How did you mount the MaxTrax to your ladder? We have a RB so it might not work but we like it a lot.
-John
2001 7.3 E350 Ujoint 4" w/ SMB Penthouse
johnandmandi.com
JohnandMandi is offline   Reply With Quote
Old 10-23-2014, 06:25 AM   #18
Found it!
viewtopic.php?f=2&t=14491&hilit=maxtrax
-John
johnandmandi.com
Old 10-23-2014, 07:57 AM   #19
macmcintire's Avatar
I attached my Maxtrax to my ladder, as can be seen in the picture below. I used 1" wide zip ties to mount them. The zip ties have lasted through a harsh winter and normal summer so far. I check them occasionally to make sure they are still in good shape.
Mac McIntire
2003 Ford E250, 5.4L V8,
Old 10-23-2014, 12:58 PM   #20
Originally Posted by JohnandMandi
Yes, you will probably have issues with the RB. I tried to keep the boards as flat as possible because I've been very close to trees and rocks with the ladders. But I'm sure you could still use compression rings to mount them on top of the ladder. Perhaps incorporate some kind of hinge to supply easy access to the ladder??? Or possibly utilize the side of the ladder and as a third point (provided a window isn't in the way) use a gutter mount and go sideways.
