Old 02-22-2012, 08:27 PM   #11
rionapo's Avatar
Re: Nato 5 gallon and 1 gallon gas cans
Originally Posted by Spenard
would depend on the elevation where bikes and fuel are located. Bikes (which are usually a bit lighter) spread the load across or to the center of the vehicle not one side. Fuel stored beside the box is lower. If it is on top of the box it could have the same effect as the water depending on capacity and containers (gasoline is a bit lighter/gallon than water).
Gotcha. So the question becomes whether 80+ lbs is significant on the right rear corner of an SMB.
-Don-
Life and baseball both sometimes are not fair, but it is how you play the hops that counts.
—Scott Miller, NYT Sports
rionapo is offline   Reply With Quote
