Old 02-02-2009, 02:59 PM   #11
Re: On the road WIFI
What's the plan and cost that goes with such a setup?
Old 02-02-2009, 04:23 PM   #12
neeemo's Avatar
There's this that just came out I guess: http://www.campingworld.com/shopping/pr ... -only/7459
Expensive and requires a cell signal. The little white cylinders evidently are antennae.
Tom
'02 SMB EB Q 4x4 Diesel
neeemo is offline   Reply With Quote
Old 02-02-2009, 04:30 PM   #13
NRL
NRL's Avatar
Send a message via Yahoo to NRL
For the cellular Data modem, I picked the unlimited plan for $60.00 per month.
Pretty much a cell phone and with most carriers, you can get some sort of a bundle package with your regular cell phone..
If you opt out of the Cellular Data Card, then there are regular cell phones that you can get a data plan with and use a usb tether to connect it to any computer to get online..
In order of speed and coverage:
Verizon/Alltel has the best coverage. (Has EVDO and EVDO Rev1)
Sprint next (Has EVDO and EVDO Rev1 Service (400kps! or more depending where you are)
ATT (non EVDO, Edge, slower but coverage is good)
As far as PC's, notebooks in general use between 2.5 to 4amps at 12V.
I was looking for something that I could leave on 24/7 with a small heat signature, so I took an older tablet pc and turned it into a mobile computer. Adding the SSD harddrive reduced the heat also since there are now moving parts on a SSD drive. I picked up a few tablet pc's between $150.00 - $350.00 on Ebay; Fujitsu Stylistic
Dlink/Linksys Router/wireless AP Hub - $100.00 if not less
Trucker/Cell Antenna with cabling - $65.00 or less
Cellular Amp (not required but does help with the range if you far from the cell towers) $250.00 or less
Having the Sporto be online and telling you it's all good - Priceless.
95 FJ80 ARB/Kaymar/Emu
2005 AMG CL65 691hp 875tq
NRL is offline   Reply With Quote
Old 02-02-2009, 04:54 PM   #14
NRL
NRL's Avatar
Tom
Yup, there has been a few new products released since we last talked about the same concepts:
viewtopic.php?p=5293
Here is another product also: http://www.cradlepoint.com/
The problem with those devices is that they work great in area that have EVDO/or Edge Cellular service but they don't auto switch to RxTT which is the lowest bandwidth mode for those data cards can do.
Most cities now have EVDO/Edge high speed internet access bandwidth (200kbs to 750kbs), then there is teh RxTT mode that the data cards can do if your really out in the boonies..
One of the most surprising locations lately was where I used to use RxTT out in Anza Borrego with a cell amp.
Sometime in the last 6 months, they upgraded about the only cell tower out in Anza Borrego near where we go and I am now getting an EVDO RevA signal!
I did a bandwidth test out in the desert and I was getting 400kbs at with a 40msec ping return which is pretty fast.
RxTT does about 100kbs(k bits per second) max with a ping test return between 300 and 400ms but in a crunch it does work if you want to get online. I've successfully got online (Amp) with RxTT 15miles away from nearest cell tower.
Now if only my Globalstar Sat phone would work when I want to call home.. Sheesh.. it's unreliable but when you've got nothing, it's last ditch effort to call home if you got no cell signal, no ham repeater tower or CB. I guess there is alway HF..
Old 02-02-2009, 07:17 PM   #15
Greg In Austin's Avatar
We have headed a little bit of a different direction with this, but....
...there are also a couple of products out there now where you can use an aircard directly in a device that then acts like a router.
This is emerging technology and in another 18 months we should see a dramatic change in what is available.
Greg in Austin
PigPen
velo47
Behemoth
Besags
