Old 10-29-2012, 09:39 AM   #11
yvrr's Avatar
Re: Outside shower upgrade
No leaking problems...I PMed you.
Jack
'01 Ford EB50p Quigley 4WD
Old 11-05-2012, 02:28 AM   #12
It turned out to be a defective mixer dial. no more leaks. Have you come up with a solution for extending the hose length?
Old 11-05-2012, 07:55 AM   #13
I was told to get a quick release hose from OSH or Lowes and cut it in. It's something I need to look into.
Old 11-05-2012, 08:46 AM   #14
yvrr's Avatar
It's easier than that. The shower head has a standard 1/2" pipe thread. Get a 1/2" PVC nipple and a regular 1/2" shower hose with female ends. Remove the shower head. Screw the nipple onto the new shower hose and then screw the nipple onto the hose from the mixer. Then screw the shower head onto the other end of the new one end of the shower hose.
Jack
Old 11-05-2012, 06:05 PM   #15
Genius. Thx. Btw smb sent me another mixer dial with hose and though it doesn't leak at the dial anymore it leaks from the head. Hairline crack at the shower heads base.
Old 05-04-2017, 04:28 PM   #16
Has anyone done the fast disconnect conversion on an RB50 with the shower mounted inside the rear door? Any tips would be appreciated.
SCMatthew is offline   Reply With Quote
