I don't remember which Zodi I used, but they're all similar. Mostly differ in size/output as far as I know. The Zodi has to be used with a stove that is a completely seperate item. Something they assume you already have since you're out camping anyway. Personally, I wouldn't use the unit on a stove inside a vehicle. We used it with a Coleman white gas stove and a little butane stove like SMB provides when you give 'em more money. Worked fine with the exception mentioned in my previous post.
The Coleman heater comes with its own built-in heating unit and uses the 16.4 oz disposable propane canisters. There is a heat control on the front of the unit that controls the water temp and it works great.
They are both set up as portable units and are meant to be used outside. We have the SMB shower enclosure that hangs on the rear doors when we need privacy. Hope this helps.
Scatter
2007 RB50, 6.0
K1WGB
