Old 02-21-2017, 07:02 AM   #1
tlg
tlg's Avatar
Rak Attach Swing Out Bike Carrier
Installed a Rak Attach on our rig. Pictures speak to quality and functionality. Rak Attach made this variant to fit an Aluminess bumper. Test fit on a van's bumper before shipping out. Provides easy access to the rear doors even when fully loaded with 4 bikes. Ended up using a Blue Ox Hitch Immobilizer II to eliminate sway. Amazing product and great customer service. Made in the U.S.A.
2014 Ford RB-50
Old 02-21-2017, 07:18 AM   #2
Bellpilot's Avatar
Nice! I like how far the arm swings out. Do you want to sell your swing out Aluminess bike frame?
2010 E350 6.0 4x4 EB 50 SMB
Old 02-21-2017, 07:22 AM   #3
tlg
tlg's Avatar
Bellpilot, I'm going to hold on to it. I originally had two bike trays up there but found loading and unloading the bikes to be cumbersome. Eventually going to put a tray up there to carry leveling blocks and recovery gear. Just need to find the time.
2014 Ford RB-50
Old 02-21-2017, 07:24 AM   #4
Bellpilot's Avatar
Sounds like a good plan! Did you build this frame?
Old 02-21-2017, 07:27 AM   #5
tlg
tlg's Avatar
Aluminess built that frame.
2014 Ford RB-50
Old 02-21-2017, 07:32 AM   #6
Bellpilot's Avatar
Thanks! We only have two bikes and use a Tule swing out now but it seems to always be in the way. Like you said the loading on an Aluminess rack is also a pain.
Old 02-21-2017, 08:34 AM   #7
MountainBikeRoamer's Avatar
Hey, super cool setup.
Currently a lot of interest getting generated in these RakAttach (and HitchSwing) setups.
Question:
How do you feel about the overall *security* of that swing-out setup?
I ask this because....
Normally, bikes can be locked semi-securely to the bike rack itself. And the bike rack can be "locked" into the hitch receiver on the back of the van (with a locking hitch-pin.) So it's *all* a "locked down/together" system.
But (briefly thinking like a thief, which you've gotta...) --- I could see how with that RakAttach.....an enterprising sticky-fingers could simply unbolt the pin which that RakAttach swings on, and then happily (if a bit awkwardly) walk off with the entire RakAttach swing arm (and bike rack/attached bikes). Then throw it in the back of their pickup truck (or truly sketchy van)...and make lost.
Poof.
A whole lot of cherished/needed/hard-worked-for gear and bikes, potentially gone.....all made possible by someone simply unbolting the one pivot-bolt.
.....So.....Yep. I'm curious.
From what you (or anyone else) can see --- is there any kind of built-in security to the RakAttach's swing-pivot bolt? (Or on those similar HitchSwings, for anyone else following this thread familiar with those?) Anything that would slow someone down from simply unbolting the swing-arm and walking away with whatever you have attached to it? If not, I'd be interested in putting some sort of locking pin through that pivot as well.
By hey!
Don't interpret what I'm saying here as anything but my "healthy paranoia" speaking.....
.....I must say that is one very sweet setup!!!!
Mike T
___________________
'95 Ford E250 RB30 PH
Old 02-21-2017, 08:45 AM   #8
tlg
tlg's Avatar
Valid point on the pivot bolt. There's nothing to prevent someone from removing it. That said, the enterprising thief would still have to deal with locked bikes and the lockable hitch pin used to mount the bike carrier. I guess the only solution would be to install a lockable bolt.
2014 Ford RB-50
Old 02-21-2017, 10:38 AM   #9
wadewaydo's Avatar
You could throw a tack weld on the nut, but of course, if a thief wanted it, he'd find a way to get it.... lock or not.
1995 Econoline E-150 Custom Campmobile "Jupiter I" RB, 4wd Dana 60s, 93 Eurovan poptop.
1976 VW Type II Transporter Westfalia Campmobile.
1994 Toyota 4Runner,2001 Ford Escape,1970 Chevy El Camino,2 Cargo Trailers, 5 bikes, 4 Kayaks, 1 Canoe
wadewaydo is offline   Reply With Quote
Old 02-21-2017, 12:25 PM   #10
dirtanddogfur's Avatar
No retail prices on their website.
Can you give me a ball park?
2012 E350 SMB/Quad Van
2021 Chevy Colorado ZR2 Bison
dirtanddogfur is offline   Reply With Quote
