Old 11-27-2012, 09:25 PM   #11
Re: ScanGauge error with high MAP
Get well soon Mike ,
The Far Aways are calling you !
Greggd
Old 11-28-2012, 10:42 AM   #12
Ain't that the truth!!!
Old 01-14-2013, 03:20 PM   #13
Finally got the van out. My bad, it sat so long the batteries went down and wouldn't start it. Charged overnight w/10A charger and it seems ok. Let it sit a week and still holding voltage and starting.
But, the X-Gauge PSI didn't work. It looks like I had TXD wrong, 3rd character should be E not 6. Maybe I couldn't read my own writing.
I went up and edited the original post to the correct values.
Next week I'll try the van again and see if PSI works.
Old 02-26-2013, 04:03 PM   #14
Got the van out, and the X-Gauge didn't work.
Finally found out that the tech gave me a wrong RXF value:
- TXD - 07E0221440
- RXF - 046205140640
- RXD - 3010
- MTH - 012203200000
- Name - PSI
RXF should be 046285140640
I corrected my first post, so it should work now. May van is down getting a new turbo, so next week I should be able to test it.
I'm going repost this in the Engine/Drivetrain section where someone who has this issue may see it.
Old 02-27-2013, 01:24 PM   #15
The final answer is the X-Gauge PSI works when correctly programmed.
Esme
Amy V
At-At
Dirk/co
