Old 02-27-2013, 06:49 PM   #1
oceansrealm's Avatar
Scangauge II transmission temperature
So I bought a scangauge II in the hopes of monitoring my transmission temperature.
I have a 2000 EB-50, V10. Have any of you programmed the X-gauge function to read tranny temp?
I looked at the scangauge manual, and it seems there are a number of inputs at several stages of the setup. However, I have no idea what to input. The scangauge manual seems a bit cryptic on this issue.
I did speak to the lead tech at the dealership before I bought the gauge and he said that the tranny temp is an output available via the OBDII port, so I just need to figure out how to configure the input.
I have the Haynes manual for this van, but it does not detail trouble codes. Does anyone have a decent source for those?
2000 EB50 4x4, V10
oceansrealm is offline   Reply With Quote
Old 02-27-2013, 07:06 PM   #2
Re: Scangauge II transmission temperature
found the input parameters on their website.
for those interested:
http://www.scangauge.com/support/x-gaug ... c-xgauges/
2000 EB50 4x4, V10
Old 02-27-2013, 08:37 PM   #3
Mine works fine, but it took a call to Scanguage. They are very helpful and will pick right up.
Old 02-27-2013, 09:08 PM   #4
MadScience's Avatar
Generally there's much more information on the scan gauge web site than in the manual. And yes, I'm reading transmission temperature on a 4r100 (with the v10) via the x-gauge. Since the process seemed error prone, I punched it in twice, and made sure the two gauges agreed before deleting the redundant one.
Old 03-02-2013, 08:44 PM   #5
Viva's Avatar
Just to add another "yep." I have the 5.4 V-8 and had programmed my Scangauge to read TFT. I then programmed a friend's for his V-10, and noticed they share the same codes (meaning, the series of numbers, etc. you enter).
I got them from the website (plus a few others, but TFT is the one I really wanted).
Serenity
Makalu1
Sporty
BusTalker
