Old 11-29-2012, 09:36 PM   #1
Tankless propane water heater
No idea if this is good or bad. Just FYI...I have an Espar
http://greenrvproducts.com/girard-tankl ... er-heater/
Old 11-29-2012, 10:17 PM   #2
Re: Tankless propane water heater
They have become optional in many motorhomes, and the reviews aren't great. The big problem is temp regulation. Unless you take a shower at full flow, the temp fluctuates quite a bit. Could be user error, but it irked some folks enough to switch to standard tank heater.
Old 11-29-2012, 11:21 PM   #3
Wonder if its any worse than the temp swing that the Espar produced w/o the tempering valve? I almost burned my scalp off.
Old 11-30-2012, 05:57 AM   #4
REF
REF's Avatar
Send a message via MSN to REF
Getting one of these to mount to my trailer...they also have a newer L7 unit, a bit bigger
http://www.eccotemp.com/eccotemp-l5-por ... er-heater/
Old 11-30-2012, 07:01 AM   #5
I have the Eccotemp 5 and I like it. Mounted on a removable container which holds my propane bottle and nearly 14 gallons of water with water pump. When I need it, I throw it in the van. When I don't, I take it out.
Harold Grissom - 2005 Quigley Ford E-350, 6.0 Turbo Diesel.
Chopperguy is offline   Reply With Quote
Old 12-21-2012, 08:11 PM   #6
loren85022's Avatar
We're using the Ecotemp-5 on the front of the trailer. If it were not on board, I'd likely be camping solo. I dont have a photo of the combo, but we've since discovered that the waffle boards I purchased for getting us unstuck someday get far more use as a shower floor.
Phoenix Arizona
2008 E-150 5.4L w/Quigley. Vangator II Wheelchair lift,
loren85022 is offline   Reply With Quote
