Old 06-30-2017, 02:25 PM   #1
achop's Avatar
What torque wrench range for 140 ftlb work?
Hi all,
I need to pick up a torque wrench where 95% of its use will be to check lug torque (140 ftlb, as per American Tire policy for my wheels, apparently). I was going to get a 1/2" drive (for beef, don't have a socket investment yet to influence drive size choice) with a torquing range of 10-150 ftlbs, given I doubt I'll need higher capacity anytime soon. Then I wondered whether it was "bad" to choose a wrench where virtually all use was at the far end of its range. Would it be wiser for any reason to get a wrench with torque range 20-200 ftlbs to avoid operating solely in the top 10% of a 10-150 wrench's range?
As an aside, the following seems like a pretty good deal ($37) on a well-regarded (as per user reviews) Tekton wrench:
https://www.amazon.com/dp/B00C5ZL0RU...=2K9TA8GOGGYSA
Thanks all,
anne
Muy Bonita - 2000 Ford E-350 V10 Quigley with 285/75 R16s, SMB-West RB50, manual PH
achop is offline   Reply With Quote
Old 06-30-2017, 02:39 PM   #2
simplesez's Avatar
your assumption is correct. The 150 ft-lb max wrench is not the one you want. Get the longer version for $52
https://www.amazon.com/dp/B00C5ZL1NS?ref=emc_b_5_t
Old 06-30-2017, 03:47 PM   #3
And always back it completely off when not using it
hogasm is offline   Reply With Quote
Old 06-30-2017, 03:48 PM   #4
achop's Avatar
Okay, so NOT the 10.5" long 20-200 with 1/4" drive (at an attractive price ;-)??? ==>>
https://www.amazon.com/TEKTON-24320-...=tekton+20-200
The one you linked to is 25" long (holy cow) ... but you make a good point. At about 140 lbs weight myself, I may have to literally sit on this baby to torque-check. ;-)
Er, Ray (who took me to buy the new tires in San Francisco) wasn't too keen on the 140 torque requirement by Amer Tire. But if y'all have a better recommendation, I suppose I could run the lugs a little lower torque ... something a bit less than I weigh ;-)
Thanks so much for the insight!
Old 06-30-2017, 03:49 PM   #5
achop's Avatar
Good reminder!!
Old 06-30-2017, 04:15 PM   #6
simplesez's Avatar
You may also need a deep socket if you have a floating axle on your E-350. Plus a 1/2" socket extension to clear your tires. You can get all that on Amazon.
Old 06-30-2017, 04:16 PM   #7
You can always use a cheater bar (pipe) on a short wrench but its a PITA. I don't carry a torque wrench in the van, I carry a breaker bar, and guess-torque if I'm in the field. I use my 26" torque wrench at home. It has been said bigger isn't always better but in this case bigger is better. I do carry a set of deep sockets, extensions and impact sockets for the larger sizes. I avoid using multi point sockets on the wheels. At least on my van the wheel lock is a different size.
Old 06-30-2017, 04:37 PM   #8
rallypanam's Avatar
Longer better.. 140 ft-lb on a 10" bar is a LOT. Especially 32 times.
Old 06-30-2017, 04:42 PM   #9
Yeah, and a 1/4" drive for large sockets is undersized IMO.
Old 06-30-2017, 05:02 PM   #10
winmag4582001's Avatar
1. Price dictates quality
2. All have a +/- of 10%
3. Back off when not in use
4. Never ever loosen with a torque wrench
5. Slow and steady until you her the click or alarm
2017 Subaru Legacy
1990 Volvo 240GL
2x 1987 BMW 535is
1995 BMW 540i6
winmag4582001 is offline   Reply With Quote
