Originally Posted by jjtwister
Great idea and it looks as if you planned it out carefully. What kind of mosquito netting will you be using for door? How will it be attached? Will it have a zipper or Velcro opening to get in and out of Van. I'm thinking I need some netting also.
BTW: if you do not already have some I suggest you Purchase some Skreenz for your drivers and passenger Windows....they are great.
Thanks!
I bought one of those screens that split in the middle and magically reattach itself with magnets, sometimes you go in and out pretty often and I didn't want to have to deal with a zipper or buttons every time.
Anyway it's not installed yet, I will give it a try and see how it goes.
they include velcro strips with the screen, if you look at my last picture, behind the bottom plywood panel (that hold the hinges), you will notice a widening gap from left to right (between the plywood and the van's side panel).
I will stick the top of the screen in there, I could even remove that rubber gasket and insert the screen in the "U" and clip it back.
I don't have "Skreenz"
I was wondering how I could improve ventilation in the van, maybe that would be the way to go?
Although I was thinking of cutting some reflectix and making shades for the front cabin, and installing a thermal curtain between the front cabin and the house...
They seem easy to DIY, either with magnets or slip on type, which one do you have?
