When we began dreaming of converting a van into a camper, the options were basically; 1) Sprinter with a high-top, or 2) Chevy/Ford and add a fiberglass high-top. Since we also wanted AWD if possible, we went with the Chevy AWD cargo van and had Van Specialties install the 24″ Fiberine fiberglass top. This gave us ~5’10” headroom after headlining/insulation/lighting was installed. The inside of the rig after 5 years of camping/daily use has faired well and looks new. The fiberglass top? Not so much. Even with washings and an occasional wax it was showing its age.
Last year during a fiberglass RV gathering we met a fellow traveler that swore by a product called
Poliglow. It was not a polisher or wax, rather a chemical coating that would typically last about a year and then a simple reapply to bring back the shine. And shine it does. Following the easy instructions took our dull white fiberglass roof back to looking-as-new.
The prep is really the only hard work, and I faired well without any aches after an afternoon of scrubbing the oxidation off (using their
Poli OX product) and then took about 2 hours the following day to actually apply the Poli Glow product. And as you can see from this un-retouched photo there is serious shine going on!
We got the complete kit with the Poli Prep, Glow, mitt, and scrubber and then added the OX to the order as we knew the surface was oxidized. Looking around at pricing you may find that ordering direct from PG will yield favorable prices.
I highly recommend this product to any whishing to breathe new life into old fiberglass. There are also several good videos online showing the simple application process for those in research mode.
: ) Thom
