Old 12-17-2017, 10:29 PM   #71
Originally Posted by bet on black View Post
I am still planning on adding an a/w ic. I bought one that is too big. Have my eye on another one, may have to do a fuel bowl delete to make a bit more room; I'm still in the planning stages for that mod.
I've read that if you swap to an '08+ front clip there's lots of room for an intercooler. A guy over on Expo put a parts list for the clip together. He did it on his Chinook for around $1300.
Edit: Oh duh. Just noticed RLwhaler7.3's front clip swap thread.
Old 12-18-2017, 09:38 AM   #72
bet on black's Avatar
i'm not a big fan of the 08+ front end look, plus i'm not sure it will play nice with my front bumper. also there is the pipe routing issue to plumb in a a/a ic.
i think i can make a small a/w work, sitting right in front of the intake spider.
that's going to be my late spring project.
'99 ford e350 - 7.3L 4x4
'10 ford f150 raptor scab
'53 buick special eight - the sled
bet on black is offline   Reply With Quote
Old 12-18-2017, 11:07 AM   #73
here are the ic's that i'm looking at:
Water to Air Intercoolers
the first one is preferred, as it is bigger, as the ports are the same 3" as the turbo outlet and intake manifold, but i may have to use the smaller one to make it fit. i'm really looking hard at a fuel bowl delete setup now to make some room.
Old 12-21-2017, 12:00 PM   #74
Started the t-case shifter install this morning before work
Old 12-23-2017, 07:36 PM   #75
I got it together enough to drive it around the block.
The Dakota digital speedo box was super easy to calibrate using my phone on the speedometer app as a benchmark. I hate how the terminal block on it doesn't hold the wires very well.
Old 12-23-2017, 07:38 PM   #76
Sprinter seats!
Old 12-23-2017, 07:40 PM   #77
Also changed the radiator tonight. Once it warms up it was leaking, seemingly from the radiator. So I pulled it and it was obvious where the top tank was leaking. Oreillys had one in stock, so that was a quick job and another $300 thrown at the van
Old 12-24-2017, 08:21 PM   #78
Aaaaaaand failed inspection due to no horn. The relay clicks, pin 30 at the horn relay has power, and the horn honks when jumped directly from the battery with a jumper...must be a bad connection or damaged wire somewhere. UGH.
Old 12-25-2017, 08:22 AM   #79
Legit! Keep up the good work!
Zappo is offline   Reply With Quote
Old 12-27-2017, 06:59 AM   #80
We couldn't get plates yesterday as the tax office was closed, so I built a quick and dirty entertainment center cabinet. That's a 24" tv. Pics are before I made the face plate for the side there
