I mounted back up lights in the new Aluminess rear bumper today. I don't have them wired yet so I don't know how bright they will be. These are the lights I ordered.
http://www.rallylights.com/detail.aspx?ID=4133
They were the brightest 4" X 6" light I could find. Hella has 3 different beam patterns in this series of work lights to choose from. I ordered the long range beam light.
They come stock with 2 55W H3 bulbs in each light. I purchased 100w bulbs to replace the 55W'ers but I am a little concerned about heat so I'm going to run with the 55W bulbs for a while.
The lights didn't fit in the bumper very well due to the lights thickness. I ended up adding a 3/4" shim between the bumper and the light to center the light up and down. I'm a little limited with the ability to aim the lights outward. The edge of the light is very close to the bumper. I think the lights Aluminess sells for back up lights sit farther inside the bumper and don't have the clearance issues.
Front view of the light
Side view of the light, note the 3/4" shim on the light mounting bolt.
Shot of rear bumper. What do you folks think of the hub cap? I like it better than the stock steel rim look
Stock steel rim look
