Old 07-09-2019, 03:08 PM   #1
lownotesb's Avatar
Brake Lines for 2003 E350
Hi there folks.
I'm the proud new owner of a 2003 E350 EB Advanced 4x4 former shuttle van. I'm basically doing a complete rebuild from seals to tires and realizing that I might as well change the brake lines while i'm in there.
Does anyone have a suggestion or source for the rigid brake lines that run from engine to rear and then again across the rear diff? I can't find anything at rockauto or summit racing. I have all the rubber hoses, just need the rigid lines.
Thanks!
lownotesb is offline   Reply With Quote
Old 07-10-2019, 12:30 AM   #2
BrianW's Avatar
My mechanic made the rear diff one up by hand using the old one as a template, with bulk tubing and fittings. Will do the same for the full-length one when I get to that. But I think the gas tank has to be dropped to get access to it.
Old 07-14-2019, 08:37 AM   #3
I highly recommend this as I had to replace this rear hardline in an autozone parking lot at 10:30pm a couple weeks ago as the factory rear hardline ruptured (due to rust) as we were coming into Santa Fe. Iím going to redo all my brake lines when I get home.
'99 ford e350 - 7.3L 4x4
'10 ford f150 raptor scab
'53 buick special eight - the sled
bet on black is online now   Reply With Quote
Old 07-14-2019, 09:03 AM   #4
Yep, a good mechanic shop can make them for you. Not your Firestone/tire store type place, a real mechanic that smokes and swears and scares you. He's your guy.
Currently vanless. Weird.
