Old 03-14-2012, 02:36 PM   #1
haywoodphotomaccom's Avatar
Build out questions...
How much if any of a passenger van interior will fit/work inside a stripped cargo van?
Can the passenger van windows be installed in a cargo?
Thanks in advance for any info.
Brent
2006 Quigley V-10 (Sold)
Old 03-14-2012, 03:13 PM   #2
Re: Build out questions...
it should all fit.... if you look in your cargo it has all the holes and cut outs for the windows and trim....
MrWicked is offline   Reply With Quote
Old 03-14-2012, 07:03 PM   #3
Ultrasport12's Avatar
Most of the intrior trim will fit/work.
The windows however wil NOT fit. While the inner body panels are the same the outer body on window van curves in around the windows. Unless you want to do a bunch of paint and body work the factory windows cannot be done easily.
2008 Ford E-350 V-10 EB
Transformer Interior
2004 F-350 Dana 60
Old 03-14-2012, 09:20 PM   #4
Bbasso's Avatar
I think it would be toooo much work/money to get the OE passenger windows in. As Ultrasport12 mentioned there are curves where the factory windows are recessed into.
there are plenty of RV type windows that would be way easier.
Here is a pretty bad pic of the factory curves:
Rob.
Current:
And had three other E350s...
Old 03-15-2012, 12:57 AM   #5
AndrewST's Avatar
The passenger interior will eat up some space in the van might be better to do custom ones.
An exemple:
Old 03-15-2012, 12:36 PM   #6
Thanks for the info all!
Any suggestions on the most stock looking window companies.
Brent
Old 03-18-2012, 08:07 PM   #7
The frame-less windows SMB offers look almost stock. I think its more a matter placement to keep the stock look.
