Re: cabinet or finish floor first?
I plan to lay the laminate down on top of the thin pad just like you would overlay in your house so that the entire floor floats. I think I'll leave a little gap between the floor and cabinets and run a bead of caulk/expansion joint material so that there isn't any actual physical hard contact points to creak. Then again, my van is 26 years old so that little bit of creaking may be the least of my worries!
Josh
