Re: Catalytic Space heater vs Furnace...
I put a atwood (I believe) furnace in my van. The curvature of the van was not an issue at all mine has the trap door on the out side to service the unit and the exhaust. installation was not that bad just a little scary chopping a big hole in the side of your van. They make units now that just have a little plate mounted on the outside of the van for the exhaust. I would get one of those if I had to do it over. Anyway a month ago in Breckenridge with the top popped and temp around zero we were at a toasty 70 degrees. Liz reached up and turned down the stat several times because it was really to hot in the van. Pretty cool considering the outside temps. Catalytics scare me something about not waking up in the morning. I would really watch it with a child in the car. Spend the money on a furnace you will be glad you did. Set the stat at 70 and sleep comfortable knowing you will wake up in the morning.
Derek
https://WWW.COLORADOCAMPERVAN.COM
00 PSD EB Quigly being converted to a Colorado Camper Van top
73 ford e100 soon to be 4wd with a 4bt
72 bronco aod injected 351 4 linked arb f/r 38in swampers
72 bronco 302 c4 soon to be 4bt w/ 5speed 4 inch lift 33 swampers
81 cj 7 in pieces at the moment injected twin turbo 401
ktm 525 exc, 620sx,
62 caddy convertible waiting for me to install 2007 northstar
