Old 12-17-2013, 06:43 PM   #11
Re: countertop ideas
Thanks to both of you, great ideas. I really like that acrylic, I'll look into that.
Old 12-17-2013, 07:42 PM   #12
Jeffrey's Avatar
I used Avonite in my home kitchen and it is very nice. Corian-like but less expensive.
Old 12-18-2013, 02:04 PM   #13
dhally's Avatar
Originally Posted by 86Scotty
... Obviously you can skip good old heavy laminate residential countertop. I used that on my last van but it is thick and heavy and I don't think it's the ideal choice for an RV. It is easy to find and use though and looks pretty good.
Thoughts?
Not sure why you say laminate is thick and heavy. The stuff I used, Wilsonart, is about 1/16" thick. It's glued onto 3/4" birch plywood and then has a rubber edge band. I think it is probably the best ratio of cost to utility. Maybe you're thinking of a pre-made laminate countertop, which is made with chip board?
2009 E250 RB 5.4L "SilVan"
Old 12-18-2013, 06:19 PM   #14
marine starboard...
This is the same material that white cutting boards are made out of. (self lubricating plastic with a fine micro texture)
Working on my wall panels in 1/4 but it comes in other sizes. Cut, shape, router just like wood.
Purchased from a wholesale plastics supplier the price is not that bad...
1/4 was about $100 per sheet (8.5' x 4) black
taylorvon is offline   Reply With Quote
Old 12-18-2013, 08:32 PM   #15
Thoughts?
Correct, I was. Mine is better than 1" thick. I had a countertop shop make it. I won't do that again.
Old 12-18-2013, 08:34 PM   #16
Originally Posted by taylorvon
marine starboard...
hmmm, that sounds interesting. I'm liking the idea of that or Avonite.
Old 12-18-2013, 10:57 PM   #17
viewtopic.php?f=7&t=12327
