Thanks, Chris. The front end has pretty much totally been revamped - I'd be surprised if any of the parts are stock Pathfinder conversion pieces. Whoever did the work did a pretty nice job in my opinion.
I went to work on the lift support tubes today. I'm not sure if they were tweaked during removal of the top or if/when the vehicle was in an accident, but lets just say they weren't exactly straight
A little bit of clamping action got them straight enough for my liking
Since they were off, I figured I might as well reinforce them with 3/4" tubing on the inside.
I upgraded the pivot bolt to 5/16" from 1/4" since the hole was a bit wallowed out anyway, but opted to leave the ends with 1/4" bolts (replaced with Grade 8's).
Note in the photo above the hole diameter in the framework in comparison with the 1/4" bolt that goes in it. I'm not quite sure why this hole is so big for a 1/4" bolt so i decided to rivet a thin plate washer to the inside minimizing movement. Hopefully this will not interfere with the spring.
Can anyone verify what the spring is held in place with? There are two holes that are about 3/4" in diameter that some sort of pin must go through to anchor the fixed end of the spring. This pipe should be more than sufficient and provide good bearing/shear on the rails.
Finally, put a color coat on the top. I'm using a oil based marine paint so time will tell on durability but I think it will serve its purpose just fine for what I'm doing. I'll do one more coat in a couple days and call it good.
I've got pretty much zero painting experience other than walls in a house, but I left the sanded texture from the primer unsanded and like the way the paint is laying on it so far.
Troysmith and I went for a short drive yesterday and it reminded me how noisy the van is between the diesel engine, gutted interior, and non existent door and window seals. I'll be excited to get the top in so I can start working on interior items though I know the electrical will take a big chunk of time before much finish work gets to start. Regardless, its still super fun to drive and a fun project thus far in its early stages.
