Old 06-16-2013, 09:45 AM   #11
Tapatio's Avatar
Re: E-Series Ford Door Panel Removal
I'll be upgrading my stereo which requires running a heavier wire to the door speakers
I would recommend installing some Dynamat while you are at it. Improves bass response and also deadens road noise.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Callsign KK6GIY
Old 06-18-2013, 02:54 AM   #12
That's a great idea Tapatio---thanks for reminding me!
Covering the inner side of the outer skin about 30% gives a great sonic benefit. I've also considered using radiant barrier type insulation to dampen the road noise ect---works wonders on the walls & ceiling for the same reason too. I'd use a water resistant adhesive like 3M's 08090; pricey but worth the cost considering its effectiveness.
