Old 07-11-2016, 11:43 AM   #1
Jolly705's Avatar
E350 Front Bumper Hitch with Brush Guard?
I am wondering if anyone knows what brand makes a front hitch mount that goes in the middle of the bumper rather than below? I have a rhino brush guard and need something that goes above it. I have seen photos of hitches that come out of the "opening" in the front bumper but can't seem to locate one online. I added a photo for reference. Thanks in advance.
Weekends are meant for being off road!
Jolly705 is offline   Reply With Quote
Old 07-11-2016, 05:35 PM   #2
Jolly705's Avatar
Okay, so I found a company in SLC that will weld one on, problem solved!
Old 07-11-2016, 06:42 PM   #3
I'm looking and near slc, can you share the name?
dick is offline   Reply With Quote
Old 07-12-2016, 09:44 AM   #4
Jolly705's Avatar
Check out GT Welding, they were recommended to me, it is $300 for hitch installed and welded to the frame
Affordable Welding Service - Murray, UT - G T Welding Incorporated
Old 07-12-2016, 01:37 PM   #5
TomsBeast's Avatar
That's what I was going to recommend, weld on a custom front hitch, either DIY or a trailer hitch shop do it for you.
I've done this mod to my current van, and a couple trucks I've owned before the van.
Both times I started with a recycled rear trailer hitch, that happened to have a cross bar wider than my frame rails, where I just cut the rail to fit, welded it in place where I needed it, then trimmed the bumper (or not) to suit.
It's getting harder and harder to find anyone in California to tackle this kind of work. It must have something to do with liability and litigious state I live in...
Old 07-12-2016, 02:29 PM   #6
Jolly705's Avatar
Luckily UT does not seem to care about welding hitches on, from the research I ended up doing there are a few places around here. Hopefully I can get it done in the next week or two. I would like the option to put bikes on the front and rear, bikes on the front and tow my dirt bikes in the rear.
Old 07-12-2016, 03:28 PM   #7
Thanks Jolly!
Old 07-13-2016, 05:08 AM   #8
Bbasso's Avatar
https://www.etrailer.com/fmr-2012_Ford_Van.htm
Rob.
Current:
And had three other E350s...
Old 07-13-2016, 10:03 AM   #9
Jolly705's Avatar
I checked on etrailer and those would interfere with the brush guard I have on the van. I think custom is the only solution.
Old 07-28-2016, 11:48 AM   #10
Jolly705's Avatar
I picked up my Van and the hitch is installed, the company did a great job. I tossed this front rack on for reference.
