Re: Electrical basics
I think he meant the Blue Sea 400a separator... Y drawing.
Also where it says "Buck?" I would move those two lines, #10 to espar and #12 to solar controller to a fuse panel fed by the #14... no reason not to have those lines fused as well. Ditto the radio switch. You can either just run the 14 across a 4-fuse block, or get a larger one and just combine the 12v distribution panel and those two lines. At the least they should have in-line fuses where they join the #14...
Napa makes a good distribution block that comes in 4, 6, and 10 fuses IIRC. They don't always have all sizes in stock so plan ahead. They also have some nice inline options too, however you need to double check the wire size- no point in putting a 20a fuse on a #10 wire in an inline holder with #14 leads...
