Old 06-01-2013, 10:09 AM   #1
Ever tried these headlights? (
I'm interested in a more modern approach which my headlights and saw these...
http://www.ebay.com/itm/92-06-E150-E250 ... c0&vxp=mtr
I can't find any pictures of how bright the upgrade would be and wondering if anyone has comments about going with a design like this.
dudewithvan is offline   Reply With Quote
Old 06-01-2013, 10:29 AM   #2
Tapatio's Avatar
Re: Ever tried these headlights? (
Yes, have them on my van. Rawdawg has them also. They are brighter than stock with a better cutoff point. Good upgrade if your stock lights are faded/fogged out like mine were.
Callsign KK6GIY
Old 06-01-2013, 11:05 AM   #3
I see you have the LED strip in there as well. Does it only come on when you turn your headlights on? I notice in the description that the strip acts as a running light, but not sure how that would work on our vans that don't have running lights. I have a 2003 model and pretty sure it doesn't.
Old 06-01-2013, 11:12 AM   #4
Gnarvan's Avatar
The description seems a little thin. When are the LED's on? Are they wired to the high beam, low beam, parking light or turn signal?
Have you considered converting to a sealed beam type headlight? I'm not sure what' involved in the conversion. If you could convert you could run a European Hella or Bosch headlight. That would give you more bulb options than are available with the 9007 bulb used in the composite headlight system.
I'm not a big fan of the plastic housings on the newer headlight systems. Over time they get clouded up and you loose a lot of light. I'll take a good 'ole glass headlight anytime.
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 06-01-2013, 01:26 PM   #5
shenrie's Avatar
thanks for the imput. i like the look of these lights, but wondered how they performed. just wish they didnt come with the led's in them.
Old 06-03-2013, 02:49 PM   #6
schluchtenflitzer's Avatar
They are also available without LED. I have them with LED and let them work with extra wires like a daylight. Took the 12V from place 21 in the fuse box (2001 E 350)
www.Dieda-unterwegs.net
schluchtenflitzer is offline   Reply With Quote
