So... How much are you going to charge for all of your new customers?
That interior has more features and options that most of them I've ever seen with a very nice fit and finish.
Rob.
Current:
And had three other E350s...
Wow. This is incredible work. Can't wait to see how she finishes up.
Could I ask a couple of random questions:
What exactly did you do with the ducting for the rear AC unit? What becomes of the ceiling-mounted controls? Just eliminate them and rely on the front dash?
Your bed solution has me fascinated. What size sleeping area that does ultimately give you? It looks huge.
STP821 As for the rear air my van is a cargo so it did not have ceiling outlets it only had plastic covers at the unit no ducts. I wanted to have my A/C come out up top and my heat down low so I went to the you pick it yard and found a passenger van pulled the rear duct and some of the grills. I tried to use the duct but did not like the size so I made one out of foam board and used to grills up top. I then made a duct for the heat and put in some smaller grills because of room I had in the cabinet face. It all seems to work good most of the time it is just me and the wife up front.
My bed came out to be a full size a little tight with two of us but not bad.
Last BlackE350 Yes I saw that thread and thought about the choices and decided to just disconnect the plunger. Drove around a few days then saw where someone made brackets to hold plunger but then they did not have security. I said to myself that is what I just did how can I come up with a way to have both. So that's what I came up with, maybe someone else already did it But I don't remember as I read so many ideas here.
