01-12-2017, 08:50 AM
#121
Ha ha, I normally drive like a GPA unless the conditions are perfect so I dont normally go hard, but I love a big hill and the feeling once that v10 kicks in.
01-12-2017, 09:10 AM
#122
In a good spot with warm engine I floor just to see. It'll rev pretty high for sure. I lost a little with the big tires, but it still goes pretty good.
<br>
01-12-2017, 10:34 AM
#123
....well, a lift without lift blocks would minimize axle wrap, but new springs with more arch are $$$ and a couple of lift blocks are $......
Not sure if there's a compatible set of springs that will lift an E-series without blocks, but if so, SDTruckSprings.com is super reasonable.
It was $250 for a brand new set of S-10 rear leafs that lifted my Astro 4" sans blocks.
2003 Astro AWD
2005 Tacoma Access cab 4x4
01-12-2017, 11:07 AM
#124
On the agile side of things, I would be very very hesitant to mess with their setup. These guys have spent years and years doing this and it's their passion. And honestly, I know just enough to know not to mess with it. And if I did, it would only be after a conversation with Agile. One could seriously compromise the handling and safety of the vehicle.
<br>
01-16-2017, 02:04 AM
#125
Originally Posted by Flux
I think Agile wanted to avoid a mess under the rig. John was quite forthcoming about the simple fact that this was only the second later model V-10 they had done. So the tank issue hadn't been completely solved as the first one ended up going to SMB for a transferflow. We talked it through and it seemed like a custom tank would be the cleanest and best solution that would also allow the build to go on schedule. I solve problems all day long so I can sympathize. The next later model V10 he deals with will be a no brainer.
All I want for Xmas is 4WD!!
Awesome. Once the tax return comes in you may have just sold a tank for Aero.
BTW LOL at the exploding rotopax armour!
01-16-2017, 05:47 AM
#126
If you have the space where the rear spare used to go under the van, or could give it up for a tank, you should look into installing the stock 55 gallon aft axle tank.
01-16-2017, 09:19 AM
#127
My tank ended up being 34ish gallons. After it was installed, there was definitely room for another 3-5 gallons which I think will be done on the next one that comes from Aero for a newer V10. That would give you 40 gallons about, certainly not trivial.
<br>
01-16-2017, 10:08 AM
#128
Originally Posted by SteelheadJones
Not sure if there's a compatible set of springs that will lift an E-series without blocks, but if so, SDTruckSprings.com is super reasonable..
Wow, their prices are great. A couple years ago I had my front springs re-arched and gained about an inch of bump travel, but they are beginning to sag back, so I'm needing to replace them. If these guys can match what I have, I'll save a ton of money over a custom set. Thanks for the link.
01-16-2017, 12:38 PM
#129
Happy to share. Hope they have a match for you.
2003 Astro AWD
01-24-2017, 02:01 PM
#130
Back to Tire Chains for a minute...
Hey Flux! Thought I'd get your attention here a little easier. You said you have RUD Chains on your rig. Which one are you using? Classic V? I have Les Schwab's , but those RUDs look a little beefier, so thinking of switching.
"RUDS I have are fairly simple to put on. You don't have to roll onto them, they have a cable with a catch on the back side and then are tightened around the front and tensioned. Hardest part is untangling them. You should drive 30 feet and retension..."
