Old 12-07-2018, 01:13 PM   #1
Fuel Line Length for Espar D2
Installing an Espar D2 in my gas E-250 this weekend and had a question around the fuel line length. As I'll be running an external tank on the rear passenger door of the van, is there a maximum fuel line length I should keep in mind to ensure the fuel pump is able to provide fuel to the heater? Wasn't able to find a specific number mentioned in the install instructions.
I'm assuming it's safe to use the full length of the fuel line provided, but want to make sure, as that will factor into the placement of the heater.
Thanks!
-James
IG: @shreddie_bettie
PulseofdaNation is offline   Reply With Quote
Old 12-07-2018, 02:53 PM   #2
Twoxentrix's Avatar
Sorry, not able to help with the fuel line question, But if your not already aware its very important to install at the angle they recommend...
Old 12-07-2018, 09:05 PM   #3
Mine is probably 15'. No problems with this length.
Old 12-12-2018, 07:38 PM   #4
Thanks for the responses.
Have mine setup and using almost the entirety of the fuel line provided in the installation kit and so far so good (fingers crossed)!
-James
Zengi
Amy V
Bullwinkle
austineats
