Old 06-27-2012, 10:00 AM   #1
Crobins937's Avatar
Got the van back from Action Van!
ImageUploadedByTapatalk1340812767.461420.jpg   ImageUploadedByTapatalk1340812783.450090.jpg   ImageUploadedByTapatalk1340812797.384463.jpg
Crobins937 is offline   Reply With Quote
Old 06-27-2012, 10:35 AM   #2
Gnarvan's Avatar
Re: Got the van back from Action Van!
Awww come on now.....you can't just post pictures without a little back story attached.
What all did action vans do? How much lift and did you upgrade the brakes?
Nice choice on wheels by the way. I'm sure I've seen those same wheels somewhere.
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 06-27-2012, 10:40 PM   #3
Crobins937's Avatar
Sorry, I took the pictures this morning and posted them while at work.
Purchased in march, the van started as Starcraft conversion van with some horrible pinstriping. The pinstriping was so bad that I had to get it wet sanded off.
I will post pictures of the interior soon. I changed out the carpet and the seats and rear bed are in good condition, so no work needed there for now.
It's a 93 E150, so the lift plus the tires gave me about a 7 inch lift.
Wheels are Eagle 100, 15x8. Tires are Yokohama geolander 32 11.5 15.
I was talking to larry at Action Van about a locker or maybe a LSD, this will probably be the next upgrade.
Old 06-28-2012, 11:03 AM   #4
BIGVANS's Avatar
Definitely get some sort of rear locker! The old tried and true “Detroit Locker” may be good (and relatively cheap) option for that van. The E-150’s semi float axle has limited choices for mechanical lockers (Eaton, ARB, etc.).
The rear end’s traction gives you a false sense of security until one day one of your front wheels goes up a slight slope and one rear wheel just spins and the van stops.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 06-28-2012, 11:20 AM   #5
Crobins937's Avatar
It's looks like the "Detroit locker" locks when needed and unlocks during regular driving conditions. Is that correct?
Old 06-28-2012, 03:11 PM   #6
BIGVANS's Avatar
Read this .....
Also, check out the PDF owner’s manual under the “Technical Information” tab.
http://www.eaton.com/Eaton/ProductsServ ... PCT_221432
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 06-28-2012, 07:47 PM   #7
Crobins937's Avatar
Thank you, this is all new to me. I have had around 10 Honda/Acura cars and nothing else.
I think that is what I I want.
