Old 09-24-2014, 10:58 AM   #21
Re: Has anyone tried these headlights?
It wasn't too bad. Just need a some extra shims because it tries to suck itself back together as you work around.
Ordering the extra sealant is not necessary. It seals itself back up nicely when you're done.
Old 10-19-2014, 12:39 PM   #22
sidetrak06's Avatar
I have these lights and in combination with good bulbs they are infinitely better than stock!
sidetrak06 is offline   Reply With Quote
Old 10-24-2014, 10:15 PM   #23
So, I bought the Cyclops adventure LED bulbs and they don't fit the plug on the harness in my van...So I put them in my 4runner where they did fit, and they won't turn on! DO I need the rectifier they sell too?
c7train is offline   Reply With Quote
Old 10-25-2014, 10:43 AM   #24
No, you probably need to re-pin the connector. LEDs won't work if the polarity is reversed, 9004 and 9007 bulbs use the same connector, but the polarity is reversed.
Old 11-14-2014, 07:47 PM   #25
Well I put in the Cyclops bulbs, I needed some adapters for the H4/9007 match up, it was a PIA, but I got them in. Well men, Cyclops adventure Sports has some of the best...customer service on the planet, but the bulbs are not all that bright in my opinion. So, I wouldn't say this is a negative review, but I'd be cautious to spend 150.00 on headlights ever again...
