Old 02-03-2018, 08:27 PM   #11
Drizzt's Avatar
Originally Posted by 1der View Post
CCV top up in winter zero degrees is what we do. Espar D4 13k btus is what we have and it works well all night. My recommendation for your rig is the Espar B4. It is what I would do without hesitation, if we had a gas rig.
Geez, just when I settled on the D2 I see this. Have you had problems with the carbon buildup others have mentioned when the temps don’t warrant high heat? What kind of temps are you using it in? Insulation in the van?
David
2003 E350 | 7.3PSD | U-Joint 6" - The Slow Build
Drizzt is offline   Reply With Quote
Old 02-04-2018, 10:07 AM   #12
I am in the same boat as the OP and others. A lot of things are real clear, until you read 2 other post that are in direct conflict.
Here is my proposed heater solution. I would appreciate any feedback.
Since my van is a V10, I decided to go with a gas heater. I know they are at a higher cost, but by the time you add a aux diesel tank, mounted underneath the van, along with all the brackets, hoses, fill port, etc., I don't think the cost will be that different.
I am torn between the B2 and the B4. First there is the cost difference, but I also wonder if the B4 is too big for my EB van with a CCV pop top. I understand if you don't run these heaters at full power occasionally, they will coke up the burner. So big is not always better.
I also need the high altitude kit for the heater. We live at 4500 ft and most camping is at high elevations.
Any feedback/experiences will help me and others.
cthayn is offline   Reply With Quote
Old 02-04-2018, 09:34 PM   #13
1der's Avatar
Our van is a Cargo with limited windows, pretty well insulated on floor and walls, and inner surface of the fiberglass top. The top is CCV w/ insulated "canvas", but keep in mind a thin layer of foam is sandwiched in between two layers of canvas. When the top is down, heat retention is actually very good. Top up nearly doubles the cubic feet of the interior and creates a sizable less insulated surface along the sides. One of these days I will get an infrared thermometer and get some readings. The test and results have been done by others in the past.
Our experience the last two years have included two six week plus "sleeping in the van" winter ski trips with temps down to just below zero, sleeping with top up. Many nights in the high 20's to low 30's in the Sierras during the shoulder months.
Greg at Lubrication Specialists in Indiana is a very knowledgeable seller of Espar units, among other things. I spent quite some time speaking with him about our usage before making the decision on what to go with. We discussed D2, D4, and even D5 with heat exchanger for hot water and heat. Greg recommended the D2 based on our rig with Pop Top and normal usage. His points were the unit will run and cycle more often on medium and will run "cleaner". His feeling was we should be good down to around zero or so.
I mulled it over and to go with the D4 (w High Altitude Kit) based on better safe than sorry for more heat, the unit running on a lower fan setting not making as much noise, quicker more distributed heating of the interior. Part of this decision was our experience using an Olympia Wave 3 Catalytic Heater (3k btus rating) for three or so years in our stock roof 15 passenger van. It was a moderately insulated van and the heater would bring the temp up to around 65 deg, but it would take 30 minutes, and without a fan, the heat did not distribute well. We liked the Wave 3 heater for what it was, but would not run it while sleeping. My logic was doubling the 3k btus to a D2's 6.5k btus and doubling the cu feet to heat and introducing a canvas heat loss area had me concerned the D2 was not going to be enough. I think this was also around the time that Bbasso installed his heater and he was really happy with his. And I chatted with a couple of owners who had D4's and were in far northern states to get a feel of their personal experience. (I would recommend speaking to Greg about the Gasoline versions of these heaters. This latest info re Gas units carbonizing up is contrary to what I was told)
In hindsight what would I do now that we have the experience? First, I do not have experience with a D2 in a rig like ours. I do not "know" if it would be enough. The D4 has performed really well and my wife and I have no hesitation of going camping no matter how cold it is going to be. We pop the top, turn the heater on, enjoy the comfort and sleep well with the heater enabled all night. We set it at around 70 while awake and around 62 while sleeping.
The only issue we had was in the second winter season. The first season I was diligent about running the heater on high before turning it off plus we did not have a built in water system to be concerned about freezing. The second season I slacked off on this practice. and because we added a water tank inside, we also left the heater on a low 45 degree setting while we were staying in a Condo for a few days. What happened was the unit never reached full operating temp with such a low setting and it carboned up enough that it would not start. I disassemble the chamber and cleaned it out. Reassembled it and got it to fire up. Ran it on high for quite a while and all is okay for now. I have added a spare glow plug and fuel screen to the back up kit.
I think we would be happy with a D2 but would have to accept a fan running at a bit higher speed and taking a bit longer to heat up the cabin. On the other hand, I am very happy with the D4, I just have to make sure I am diligent about running it on high for 5 to 10 minutes before shut down.
Old 02-05-2018, 12:34 PM   #14
Ray,
Thanks for the detailed discussion. I was looking for some real world experience with these heaters. Your input was helpful.
Does anyone have input on the best controller for the Espar heaters. The online vendors have no details on the options and I can't find a lot on the manufacturer's site (maybe I need to learn German).
It seems that the controllers are focused on truckers. I would like a simple controller that allows me to set a temperature. Programming a start and stop time would be nice too.
Thanks
>> Corey
Old 02-05-2018, 12:53 PM   #15
Just got off the phone with Sergei at Planarheaters.com. According to him...
...the Planars operate just fine to about 4000ft. Above that, he recommends burning kerosene, which would be "no problem" at altitude.
He had a Russian accent, (and his name was Sergei) so I asked a bit about the origins of the heaters. He says that he is in BC, and is the authorized U.S. and Canada distributor. And that the heaters are made in Russia...which seems to be at odds with Scotty's info.
Hmmmmm.... It's not getting any easier.
MorieSugg is offline   Reply With Quote
Old 02-05-2018, 09:27 PM   #16
Well I'll be. It appears you are right. I was simply passing on info that I read somewhere which was obviously wrong. Backwards basically. They are made in Russia and exported to Canada....and other places. Read up, from the 'about us' link on the bottom of their web page:
Planar Heaters. About Us
Old 02-05-2018, 10:12 PM   #17
Bbasso's Avatar
Yup, I'm incredibly happy with my D4. If it's under 65 outside my heater is set to 73, day and night.
Have you seen the cheesy and not sober video I made a while back? I was in Branson, MO for Christmas- cold AF!
Rob.
Current:
And had three other E350s...
Old 02-05-2018, 10:14 PM   #18
Bbasso's Avatar
https://youtu.be/A2tFR-_WV9k
Rob.
Current:
Old 02-07-2018, 10:04 AM   #19
Thanks Rob. I'll be looking for all the help I can get when it comes time for install.
I think I'm leaning away from the Planar. Not that I don't totally trust the Russians, but.....
I'm also realizing that some of my understanding of pricing was off. Maybe way off. I swear I've seen some of those prices in the past. Are the prices on these units going up? I was reading a Sprinter Forum discussion about D2s where it was suggested that demand is driving prices up recently.
Mostly due to price, I think I'm leaning towards the D2 with an on board diesel tank. It might be a tad bit undersized if want to winter camp with the top popped, but that probably won't be with my kids, and I've winter camped in a tent with no heat source enough times that a heater keeping things above 40 will be luxury.
Anyone bought one recently and got a good price? I think the best I've found is $900, not including High-Altitude kit.
...or, if I anyone knows a source of a B4 for less than $1800, I might could reconsider sticking with gas.
Old 02-07-2018, 02:14 PM   #20
The folks over on Promaster Forum seem to prefer the Webasto 2000 STC Petrol heater over the Espar, perhaps for cost reasons. Here's one thread discussing Webasto installation and costs:
Webasto Gasoline heater - Ram Promaster Forum
Single gasoline fuel source is definitely one of the key advantages.
PeteM is offline   Reply With Quote
