Old 01-22-2018, 11:29 PM   #41
Originally Posted by 86Scotty View Post
How do I resist making a junior high joke about the above post? I typed it out 2-3 times and then just gave up. Anyway, thanks for the laugh.
OK, maybe just a small sample.....Have any video of that?
I'm not allowed to take video, but the sound effects are pretty good as she slips into her bag with the hot tube fully extended.
Old 01-23-2018, 07:23 AM   #42
OK, where were we.
I think we were discussing more long term heating methods.
Old 01-23-2018, 02:04 PM   #43
rockbender's Avatar
I nearly had to click the 'thanks' button, as in 'thanks for the laugh!'
I need to think about a way to redistribute heat up into the penthouse too. I might just drop in a vent/muffin fan towards the rear somewhere to allow the warm air trapped below to circulate. I wasn't smart enough split my hot air output and plumb an outlet up through the cabinets, though I doubt the little propex has enough air flow to support two vents very well.
Josh
Old 02-11-2018, 11:35 AM   #44
Blowby, I finished the installation of the B4 into my van yesterday. I say finished, but I still have to clean up some wiring runs, build a protective shield/box, etc... but it's working and blasting heat!
As is typical with my projects, it took much longer than anticipated, but that's part of the fun. Now it's time to hit the road and find some snow (because California has NONE!).
I'd also like to note that I purchased my Espar from Heatso, I have no affiliation with Heatso - their customer service is top notch. I had neglected to order the floor mounting bracket but then realized I needed it... they got it to me from the UK in 2 days! So I'd recommend them if you're in the market for an Espar.
2001 E350 Cargo V10 Quigley 4x4 Voyager Top
DIY build underway
ApacheCheef is offline   Reply With Quote
Old 02-11-2018, 03:05 PM   #45
4x4sporty's Avatar
I've heard of more trouble with the gas ones than the diesel
What trouble have you heard ?
4x4sporty is offline   Reply With Quote
Old 02-12-2018, 09:24 PM   #46
Blowby's Avatar
Good to hear that you were able to get the B4 installed!
I know exactly what you mean by "it took longer than anticipated" am finding this out myself.
A couple of questions if you don't mind?
Did you install through the pump base on the top of the tank, and what controller or add on's would you recommend?
High altitude kit for me is a must ,but would like to hear any other recommendations or tips.
Thanks Roger
Blowby is offline   Reply With Quote
Old 02-13-2018, 09:56 AM   #47
I'll try and find it. First, I just read it once or twice so that doesn't mean it's gospel. I'm following about 5 or more Espar/Webasto/Planar/etc. threads on a few different forums. More people than ever are adding the gas ones and somewhere I read they build up carbon even quicker, which is a bit counterintuitive to me. I'll link if I can find.
I'm super glad people are jumping on these gas or diesel. They are a huge improvement over the old huge propane RV heaters in every way.
Old 01-19-2024, 07:51 AM   #48
Tapatio's Avatar
Originally Posted by hein View Post
I put a lawnmower air filter on the combustion intake hose. Something like the filter at the link below. I don't recall the size of the black hose so verify that first. I picked up the one that I used at our local ACE store and it fit perfectly.
https://www.amazon.com/Oregon-30-091.../dp/B0018U00BU
It is a combustion chamber so deserves clean air, imo. I also installed an air filter on the return air inside the van.
I use these. I had to send my Espar in for service after it blew a bearing. Dirt was the culprit.
Powtol 36905 Air Filter for Toro Recycler 22 GTS 6.5HP 20016 20017 20018 Lawn Mower Tecumseh 751-11122 LV195EA with RJ19LM Spark Plug (Pack of 2) https://a.co/d/7OBwJ4K
Callsign KK6GIY
Tags
diesel, espar d2, heat, heater, install
Silver Streak
Glider
Otter
