Re: Installing a floor in the van
Bondo and lots of it. We put bondo over all the screw holes, all the gaps/seems in the wood, over both fenders and the doghouse cover. Pretty much everywhere and anywhere there was any kind of crack or gap. The, came the sanding. The fastest way to sand down dried bondo...angle grinder. I started using a palm sander but it was taking too long. Busted out the angle grinder with a worn down grinding wheel and voila! It also knocked down the wood where it was higher than the piece next to it making the floor nice and smooth. You have to be a little careful over the glass, but you can get pretty detailed with the angle grinder.
Then, after the grinder takes down all the big ridges, it's time for sand paper.
