Old 02-14-2017, 01:48 PM   #1
luked's Avatar
Interesting heat solution based on water heater
Anyone seen something like this? I'm installing a 6gal propane water heater and this may be a cheaper solution to a propex heater. Doubt it would work in sub zero but who knows. I thought it was worth sharing
starts at 7:25
basically propane water heater, water routed and pumped through a small radiator with 12v fan that blows across it to heat the van. Obviously works like a typical water cooled engine heater but without the engine running
Luke
Home Built Camper Van - 2003 EB 15 Passenger, 7.3 PSD, Ujoint 6" Lift, 35x12.50x17E BFG AT KO2 , MSD High Top, Hand Made Interior
luked is offline   Reply With Quote
Old 02-14-2017, 05:32 PM   #2
Bbasso's Avatar
Seems simple on the outside but would be rather complex to have it run properly.
I'll stick with my Espar D4
Rob.
Current:
And had three other E350s...
Old 02-15-2017, 02:42 PM   #3
You can get water heaters that come with three ways to heat the water.
1. Engine.
2. Propane.
3. Electric.
I had one of these and always thought it would be a good idea to just add a small 12 volt circulating pump to the line that was being used to heat the water from the engine. In the Winnebago that I had there was also something they called "Motor Aid" that was really a radiator and fan using the engine hot water.
So by adding a small pump I could get heat to the "Motor Aid" from the engine when it was running and from the hot water heater when the motor is not running.
Killed a lot of birds with a single 12 volt pump added. Heat from Propane, Engine, Electric, and stored in hot water.
What I didn't figure out is how well it would heat the RV.
I think you have a good idea since great minds run along the same lines.
2015 Promaster Sportsmobile
KB2ZE
Old retired IBM Engineer
DCHitt is offline   Reply With Quote
Old 02-15-2017, 04:00 PM   #4
LenS's Avatar
Have a friend who heated his basement in Iowa that way. Used his house water heater as the hot water source and floor radiators in the various basement rooms. Worked fine.
Len & Joanne
The Green TARDIS
