Old 04-13-2011, 01:47 PM   #1
4x4tour's Avatar
Manual Lift Assist - Easy solution
Since I already carry one of these in all of my vehicles, I thought of using 3 collapsible square metal tubes (with pins) on top of this cheap ($40) remote operated 12V 2-ton harbor freight jack (using 2 bolts crossed at the bottom to fit in the jack slot) to manually lift the top for those sore back/neck days. I would simply make a plate and bolt it under a seat cushon, that would double its job, to disperse impact with the top.
Yes, and it also lifts my heavy 1-ton axles (small bursts on the button saves the tiny amp fuses they supply)
"Keep your blade sharp, and your wits even sharper..." - Role Models
4x4tour is offline   Reply With Quote
Old 04-14-2011, 05:23 PM   #2
Re: Manual List Assist - Easy solution
I copied this topic to: General Sportsmobile so everyone has a better chance to see it. Not everyone reads the Homemade section.
