I'm almost 100% sure its a D60. The 10.25 looks to have a 12 bolt pattern. Since nothing happens without picture this is where we are at.
Dealt with a lot of snow and freezing temps:
I don't believe in shoveling driveways
But we go a lot play time in for climbing and skiing:
My work in progress all winter was to get power into the van. Wasn't really sure how to do it but this was my solution:
I went with the marinco 30amp twist lock outlet
Cutting a hole in the side of the van was a pretty sphincter tightening experience (only took 2 hours to commit to drilling the pilot hole...)
Which runs to a 30amp breaker box
The outlet gives us one 110v option and powers the converter.
The starter bateries are connected to a 155ah AGM via a T-maxx battery isolator (thought about just buying an isolator but liked the extra security of being able to link the batteries with the touch of a button if I kill the starters, not a 100% sure its worth the extra $$ but the voltage meter is nice).
The house batter then connects to the 12v fuse box and the inverter through a blue sea battery selector switch via 100 and 200amp breakers.
Here it is with the closet bottom in place.
I still have to work on protecting the power contacts.
I still have to paint the back of the switch panel black. I'm not sure what I thought I was going to do with 8 switches, so far ~5 are going to be used. I messed up a couple spots on the plywood so will probably fix and downsize the panel later.
We got our fridge the other day so its wired in and awaiting its slider so I can start building the frame for the sink.
And of course my trusty assistants...
Thats all for now. We got a few of the LED house lights wired up, they are really bright and we will not need as many as we were planning for. I have to pull the trigger on a locker and but mountain bike season is here so she will start seeing more miles again (starting next week when we head for NC).
Jeff
