Old 06-30-2017, 06:44 PM   #1
Must Have Wifey Item
Shower pan/drawer under construction.
Thanks Mike
Tienckb is offline   Reply With Quote
Old 06-30-2017, 06:55 PM   #2
MountainBikeRoamer's Avatar
Great idea!!
Very cool / cleverly packaged solution.
Where will it drain to?
Some sort of flex line attached beneath it? Or is it positioned directly above a drain hole of some sort in the floor?
Mike T
___________________
'95 Ford E250 RB30 PH
Old 06-30-2017, 07:01 PM   #3
It will be routed to a 10 gallons gray tank underneath. Flex drain line is what we have in mind. Still waiting for Mike to finalize the design.
Old 06-30-2017, 08:49 PM   #4
Glider's Avatar
Very impressed! Love the idea. More pics, please, after you have the drain worked out. Curious minds want to know...
2006 SMB EB45ish.
5.4L, QuadVan 4x4
Ready to Rumble!
Old 07-01-2017, 06:23 AM   #5
E-rex's Avatar
Clever use of space. Will the drawer be supported from underneath when in use (rather than put all the load on the extended slides)?
Would any support come from the drawer face contacting the floor, or would the pan be resting on some kind of support as well?
'08 E-150, std roof, wb, 2wd - basic cleanup done. Working on rough layout of 'furniture'.
Pretty much everyone will step on their 'willy' once in a while.
I usually make it a point to stop and put on my golf shoes first..
E-rex is offline   Reply With Quote
Old 07-01-2017, 08:16 AM   #6
I want to know too, but I'm guessing the double slides and the drawer face hold it up. There's usually enough flex in drawer slides where it would slide out without much force and still seat to the floor on the drawer face without tweaking anything. Still, I'm also anxious to hear.
I have seen a really narrow floor drain before but can't remember where.
Very cool stuff!
Old 07-03-2017, 10:26 PM   #7
Super smart! I built my fridge with accuride slides that are lock/in/lock/out and 500lb weight capacity. I'd bet this will work awesome and only need a curtain to prevent water from splashing back into the wood.
ohpyramids is offline   Reply With Quote
Old 07-04-2017, 12:02 AM   #8
MadScience's Avatar
+1 on wanting to know how this will drain.
I like how it looks regardless.
